928 Forum 1978-1995
Sponsored by: 928 Specialists
dot 3 or dot 4 brake fluid
Old Feb 7, 2005 | 01:16 PM
the flyin' scotsman's Avatar
the flyin' scotsman
Default dot 3 or dot 4 brake fluid
I'm curious as to the consensus on brake fluid type for hard street use in our cars.
The WSMs advice using Dot 4 fluid in the brake system and the owners manual suggests Dot 3 or Dot 4. The cap on the brake master cylinder is stamped Dot 3.
Dot 4 has a higher boiling point suggesting that its the fluid for harder use although I'm not sure our cars braking system gets to the higher temps even with hard street use.
Any thoughts? TIA...............Malcolm
Old Feb 7, 2005 | 01:31 PM
John Veninger's Avatar
John Veninger
Castrol GT LMA(low moisture activity) brake fluid is a DOT 4 and good for the street.
Many track drivers use ATE Super Blue, but it is changed more often then typical street cars.
Old Feb 8, 2005 | 09:01 AM
Garth S's Avatar
Garth S
The Castrol LMA is also my choice for the street - primarialy based on the reduced hygroscopic/moisture absorption claim ...
Old Feb 8, 2005 | 10:28 AM
Mark's Avatar
Mark
ATE Super Blue!
I have also used the Castrol DOT 4 synthetic, but like the super blue. Also, as it is available in different colors, it makes a full fluid change/bleed SO MUCH EASIER!
***Call 928 Spec and get the "Power Bleeder" . Makes the job FAST and EASY! By far, the best $39 I ever spent on a tool!
Old Feb 8, 2005 | 10:32 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
There is no advantage at all to using DOT 3. DOT 4 is better fluid, and the cost differential is inconsequential.
Castrol LMA is good fluid, as is the ATE, and as is any name brand synthetic DOT 4.
Do NOT use silicone fluid!
Old Feb 8, 2005 | 10:13 PM
jheis's Avatar
jheis
Malcolm:
My recommendation is Valvoline SynPower synthetic formula. It has a dry boiling point of 480F and a wet boiling point of 330F - higher boiling points than either Castrol or Ate and it's readily available at auto part discounters for around 5 or 6 bucks a quart USD. Ate is usually at least twice as expensive.
James
