Tank venting valve test values
Im not sure of the value but i can tell you to the "nats ***" where it is powered from these days!
on an 87 s4 atleast...
Pin w-13 on central electric via 2.5 Red/yellow to hard point 4 ... via .75 red/yellow to pin 1 on the connector returning via .75 Brown/yellow to pin LH 27
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
![](http://members.rennlist.com/v1uhoh/injectorplugs1-16-3.jpg)
Thanks Tony,
Schocki needs a resistance value for some checking. The vent valve is the one component that I've not checked.
Good luck with your fault finding !
