Managing a slack timing belt.
I started the car some 260km from home and 3 minutes later the slack T-belt warning came on. I cancelled it and had driven gingerly for over an hour assuming it to be a false alarm when it came on again. Scared the sh** out of me. Cancelled it a second time and it came on again in about 10 minutes on a bumpy section of road. 3 times false alarm? Unlikely. I had to believe it this time so I stopped at a restaurant, opened the bonnet to let it cool and went for lunch resisting the temptation to drown my worries.
By great good fortune I had with me a good toolbox including some sawn-off spanners which fit the belt tension adjuster with a litle fiddling. After lunch I tightened it just 3 flats, started up and drove carefully 100 kms home without another warning. Now 2 days and 200 more kms later and still no red lights.
I had not checked the tension in over 10 000km. My assumption is that the belt had just exceeded the limit of stretch and triggered the alarm as it should. I'm going to check the tension properly this weekend but for anyone in the same situation this seems like a useful get-you-home trick.
Colin. 89GT
Colin. 89GT
Range Master
Pepsie Lite
Pepsie Lite
Maybe, unless the reason is one of several not actually related to the tensioner setting itself....IE bad H2O pump bearing, bad tensioner rollers, a bent tensioner bolt, shreaded belt, loose cam sprocket bolt...I could go on, but you get the picture I suspect.......
You take a real chance on trashing your motor when you ignore the warnings....sometimes lady luck shows you some mercy, sometimes not......Ask Big Dave if you need a war story....
Colin you have thus far been LUCKY but making an assumption that the belt is simply loose is really not something to recommend that other people should try. Plus you still do not KNOW what if any problem you might be having. One of the problems we see often is overly tight belts with resultant wear on the gears, water pump and occasional broken cam shafts. It is good you made it home but why are you still driving it ? The mentality of "trying to make it home" has cost many people far too much. Betting a $200 tow bill against a $5,000 valve job ; right now you are up about $400 and still rolling the dice. This is a really bad idea.
928 Collector
Colin, they are 100% right.
There is a reason the belt was suddenly loose after so many thousands of k's .... that reason is not that the belt stretched. I can attest to that first-hand in many different ways. See my Euro '85 thread for a nice pic of the belt
How long has it been since your last confession? .... I mean, your last tbelt/wpump job?
928 Collector
My mom and her hubby drove from OVS (afr) to Kaapstad recently. Well ... they were on the way that is ... in their brand spanking new Mitsu full-sized bakkie. Somewhere under the starry sky, you know the type of place .... it's 11pm; you're in put-sonder-waterfontein .... and the red lights come on ... (of course they deny this) .... but they have to get her home. So, they drive on, and I can imagine him: "Come on Baby, just get us to the nearest garage" ..... when, no surprise to a fellow like me, but a major surprise to an older couple like them .... "BAM!!!!!!"
13 thousand bucks later .....
Range Master
Pepsie Lite
Pepsie Lite
Yep, try it with an Audi engine and you'll get no second chance with that one either.......The 928 engine is actually very forgiving, but when she has had enough.......she can be a VERY high maintenance girl..........
I only turned mine 2 flats and no worries, 10000 km later. NOT! WTF!! OK, I know we're not the only English speakers, but care to let us in on the jargon, what "flat" refers to in wrench language we all understand. Would that be 3 sides of a hex head -- equals 1/2 turn??
Lastly, it could be a short you're having (can't imagine what that translates to in your jargon) but like Jim said, you can either go to the casino 'cause you're on a roll or more likely , stay away, 'cause you have used up your luck, it's your choice.
Range Master
Pepsie Lite
Pepsie Lite
AND FER GOD'S SAKE, HE DID IT TO AN 89GT!!!!!!!!! CRIMINAL man.......
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
928 Engine Re-Re-Rebuild Specialist
I had a loose belt warning. I tightened the belt. I got another one a few weeks later. I tightened a little more. Then disaster struck.
Find out why it's becoming loose. NOW.
