Tempature Guage Wiggles At Times
After engine is warm , the temp. guage will wiggle at times & is showing about 1/4
the way up. At times it will shake . Then later when I look down it is perfectly still & sitting about in the middle . Is this maybe a loose connection at the sending unit. If so where is it located? I have a 86 928s . THANKS in Advance!
THE FARMER
THE FARMER
Rennlist Site Sponsor
Iris Blue is a beautiful color, whether it is the light blue like our '86s, or the dark blue as on the GTS...
The temp sender is top center of the engine - front of the intake manifold. But - your problem is more likely to be a bad connection on the flexible circuit board inside the pod..
Or a loose connection anywhere in the circuit.
The temp sensor wires are blue/green and blue/yellow. They enter/exit the Central Electric Panel on M24 and M25 (Plug M, 4th wire up on the right side and 5th wire up on the right side). On the instrument side, they enter/exit on L14 (Plug L, 4th wire up on the left side, goes to terminal 13 on the pod circuit board) and L15 (Plug L, 5th wire up on the left side,goes to terminal 15 on the yellow side of the central warning computer in the driver's footrest).
If you can get the gauge working by wiggling the cluster it will be most likely a failed gauge. Here is a link how I fixed mine Roger's GTS had the same bad solder spot!
https://rennlist.com/forums/928-forum/149496-finally-oil-pressure-gauge-repaired.html
HELP!
Any help would be greatly appreciated
Tarek
Temp gauge fluctuates
THE FARMER
THE FARMER
Hammer
Originally Posted by 6.0-928S
I worked at Holbert's Porsche in the late 80's & early 90's. There was a tech bulletin about this problem. As a matter of fact I have my own (86.5) dash out at the moment to install Jager's LED lights, & my gauge does the same thing. The bulletin said that the problem was likely at the dash circuit card connection. It suggested bending the harness terminals in the connector for more tension & applying dielectric compund to the card terminals. Rather than remove all those terminals from the housing, I popped out the black retainer that holds on the terminal pin housing on the back of the pod, then lifting up the card & spaced it up with a piece of the card material that I snipped off one of the edges. Then I put the dielectric compound on the terminals. I haven't finished reinstalling it yet but that's where Porsche suggested the problem was.
Hammer
Hammer
