928 Power Window Blues Help!
Driving home today I decided to roll down my windows and open my sunroof. Everything opened fine but when I tried to close them "nothing". I figured it was a fuse but both the sunroof and the window winder fuses were good. Using a test light I discovered the fuse has NO power on either side. The VI relay (Third black relay from left to right) is supposed to be the window winder could this be causing the issue of no power to the fuses? I jumped power to the window fuse and was able to roll them up and then I jumped power to the sunroof fuse and was able to close it. Really wierd it has to be the Window Winder relay right? If it is WHO sells them? I cannot find them anywhere... Thanks for any help!
One more quick question, on the wiring diagram I see a "Control Unit Power Window Regulator / sunroof" is this the ralay or something else I am not familiar with? It seems suspect to me as the Sunroof and windows both astopped at the same time. Thanks!
