Correct Rotor Install
Hey, All. I have a simple (hopefully) question. I took both rotors off during my recent timing belt tensioner rebuild. I am putting on the new rotors and realized that the bolt hole pattern will allow the rotors to be mounted 3 different ways. Looking at the sprocket on the end of the cam shafts I noticed that their are 2 small lines that are made into the sprocket casting. They radiate from the center outward. So I mounted the rotors such that the contact arm of the rotor ligned up with these marks. Is this correct? Anyone have a picture of the correct mounting on the sprocket?
Rotor installation
They will only go on one way. The holes are not equally spaced.
Jim M.
93 GTS
Jim M.
93 GTS
