928 Forum 1978-1995
Sponsored by: 928 Specialists
Hall sensor?
Old Jan 10, 2005 | 07:27 PM
gf261's Avatar
gf261
Default Hall sensor?
I am having a bit of sluggish acceleration off the line with my 89' auto. Everything sounds good but it is obviously slower than my 87'. The previous owner told me that the hall sensor needed replacing as it retards ignition somewhat if not functioning properly. In the VAST amount of documentation that he gave me with the car, I found a receipt where the hall sensor had been replaced prior to his purchase in 2001 at 119,XXX miles. It is on 133,XXX now. Are there two hall sensors? Could this one have gone bad in that mileage/time frame? Any opinions or suggestions welcome. Thanks!
Old Jan 10, 2005 | 07:34 PM
Jim bailey - 928 International's Avatar
The hall sensor retards timing BUT also the two knock sensors if one fails retards timing. Also check for a stretched throttle cable not giving full throttle , flappy resonance flap not functioning. Mass air flow not working at 100% , full throttle switch not working. ......
Old Jan 10, 2005 | 09:01 PM
gf261's Avatar
gf261
Both knock sensors replaced at about the same time as the hall sensor. Flappy valve fixed by PO and Wally at last years SITM. I guess mass air flow is next on the list. Thanks Jim!
Old Jan 10, 2005 | 10:10 PM
Ed Taylor's Avatar
Ed Taylor
Garrett, Did you get the red 89 from Tim in Fla? If so that car had a good wrench while it lived in Atlanta.
Old Jan 11, 2005 | 08:49 AM
John Speake's Avatar
John Speake
Could be the MAF, if it's not been replaced yet.
Old Jan 11, 2005 | 12:02 PM
Garrett ,Why not try swapping the mass air sensors from your two cars ?
