custom camshaft timing and valve clearance
Originally Posted by UKKid35
I suspected this when setting the cam timing with a new belt buring my engine repair, but I found no mention of this issue in the WSM. It would have been nice if there were different specs for brand new belts to deal with this issue, particularly the imbalance between cylinder banks. Sadly it wasn't possible to use my old cam belt...
![](http://img30.exs.cx/img30/4741/beltinfo9wa.jpg)
Originally Posted by drnick
z, just re-reading your post. it seems that the cam lobe seperation angle did not change for any of the 32v cams, hence the reason people are now mixing and matching to optimise performance??
assuming my cams have been ground symetricaly and without any change to the lobe seperation angle and presuming i can find out the crank angle between my exhaust closing and intake opening, how does one then set the timing - practicaly? it seems i could choose somewhat arbitrarily between the GT and 85-86s 1 crank degree vs 7.5? what i mean is, is it practical to determine physicaly these points on the engine?
On the other cylinder bank, put the dial indicator on the #6 cylinder intake valve lifter and use the same procedure. With the firing order of the 928 engine, the indication on the balancer would be the same since both the number #1 and #6 cylinder would be at the top at the same time. The difference would be that one cylinder would be about to start the intake cycle and the other would be about to start the power cycle.
The specs for cam lift and timing are often given at a lift of 1mm. If that's the case, the procedure to determine the center point between the exhaust and intake valve lobes would be the same. It would result in the same physical center point location between the cam lobes, but the degrees of crankshaft rotation would be a smaller number. Then instead of watching the dial indicator to see at what point the intake valve lifter just starts to open, you'd watch the indicator until the lifter opened the intake valve 1mm.
If you do try this, make sure you securely hold the cam when you loosen the sprocket on the front of it. With the engine in that particular position, some cam lobes for some cylinders may be in a position that places them holding some valves partially open against the valve springs. That means that there's the possibility of the spring pressure suddenly rotatingthe cams if you just loosen the bolt(s) that hold it to the cam sprocket. With a pistons close to the top of their travel, any sudden and unexpected cam and therefore valve movements could possibly be not good. It's probably safer to check as indicated above to know where you're at initially, and then turn the crankshaft to close to where the manuals say to adjust the cam timing at. For example, if you want to retard the cam timing 2 more degrees from where it's at, turn the crank to the 20 degree after top dead center position that the manuals state and note the dial indicator reading of the lifter. Then loosen the cam sprocket, and turn the crankshaft to the 22 degree after top dead center position while making sure that the dial indicator reading stays the same, and then tightening the cam sprocket.
hi z, im still waiting to confirm that the lobes are in the stock axis but i did speak to my mechanic and he went through this with me too. seems the specs for my cams are really not that wild and close enough to the GT and 86.5 on the intake side. his only concern was with the extended duration of the exhaust side, however if we advance the timing as per the GT this should reduce any possible risk of valve to piston contact.
in terms of determining the crank angle between exhaust closure and intake opening, it seems to me that this will only be possible once the cams are installed, with the use of dial gauges. one thing that has me confused is the disparity between the printed specs for stock cam duration as opposed to the timing of valve opening and closure, whats that about?
here is the spreadsheet data i recieved today from piper cams. the overlap is indicated at 33 deg with full lift timing at 110 deg ATDC for intake and BTDC for exhaust. not sure what the stock full lift timing is though, given that the intake and exhaust are linked by chain.
You have 33 degrees of overlap according to that information you got. I have to ask if you're planning to try to pass any kind of emissions test with these cams. I'm kind of hoping your answer is that you're not.
Originally Posted by Z
Apparently sometime in '87 Porsche started to use a belt with some degree of pre-stretching, which would reduce the effect of the cam timing change. Rumor has it that the Porsche timing belts have less of an initial stretch than other brands. I have absolutely no idea if that's actually true or not. Since Porsche is not in the belt production business, and I doubt in the belt pre-stretching business either, I have to wonder if there's really any difference between the belts that the manufacturers make for Porsche, and those that they put their own name on. Everyone did make sure to put their new belt on with the lettering right side up when looking at the engine from the front, right?
z, no emissions testing needed. the info from piper assumes full lift at 110 deg either ATDC for the intake or ABDC for the exhaust, the difference between them is 180 degrees. however porsche have larger gaps and as there has not been any change to my lobe seperation angle, i calculate the difference will be greater when installed in the standard manner as per porsche giving a difference of aprox 237 degrees. that is max exhaust lift at about 70 deg ABDC and max intake lift at about 127 deg ATDC. maths isnt my strong point but i make my timing figures to then be
intake: opening 0 deg ATDC
closing 74 deg ABDC
exhaust: opening 56 deg BBDC
closing 16 deg ATDC giving 16 deg of overlap!
the discrepancy i mention between published specs for duration as compared with the published valve opening and closing data. take the GT intake as an example; opens 3 deg ATDC closes 42 deg ABDC giving a duration of 219 deg as opposed to the measured 258 deg?
closing 74 deg ABDC
closing 74 deg ABDC
closing 74 deg ABDC
The exhaust opening and closing events that you gave above are correct. The intake opening and closing events are not correct, because you apparently arrived at them based on the mixup of ATDC for BTDC.
The correct timing figures should be:
intake:
opening 17 deg BTDC
closing 57 deg ABDC
exhaust:
opening 56 deg BBDC
closing 16 deg ATDC
That gives you 33 degrees of overlap. That cam timing also places that lobe center point I mentioned earlier in this thread right at top dead center, which is 1 degree more advanced as compared to the centerline of the stock GT cam timing specs.
quite right z, regarding my incorrect calculations. looking at the timing specs for the stock GTS the manual lists the following:
intake opens 13 deg ATDC
closes 61 deg ABDC
exhaust opens 28 deg BBDC
closes 12 deg BTDC
which i see now are measured at 1mm of lift! from this ive derived full lift times of 127 deg ATDC for the intake and 110 deg BTDC for the exhaust giving a difference of 237 deg. this gives me the same intake times i posted earlier zero deg ATDC and 74 deg ABDC and an overlap of only 16 deg. granted my math were in part faulty before, but is this not what i could expect if set to the stock GTS timings (for full lift)?
if so, should i try any more advance?
closes 61 deg ABDC
closes 12 deg BTDC
Hi DrNick, did the cams look real nice after they came back from Piper? Did they assess the hydraulic lifter at all for you? I'm just wondering, if you went to solids, how much extra duration you would get. There is a place in the U.K that sells DLC coated solid lifters for the 928. These will give you 2% extra power due to the lower friction according to the manufactorer. I don't doubt it I have studied a little on the friction front in the valvle train, there is a lot. Plus you may pickup some exta duration.
Cheers Greg
Cheers Greg
greg, if you went to solid lifters do you also need shims? how often would you have to check valve clearances? i like the idea of self ajustment with the hydraulics.
