928 Forum 1978-1995
Sponsored by: 928 Specialists
Reassurance requested
Old Jan 1, 2005 | 06:01 PM
bd0nalds0n's Avatar
bd0nalds0n
Default Reassurance requested
Okay, so today I was outside, taking off the SC and the intake manifold to install new gaskets and fix my intake leak. Once I got the manifold off, I shined a flashlight down all the intake ports just to make sure I didn't get anything down in them.
And of course, when I look in the one on the passenger side, at the front of the motor, I see that there's a little piece of either plastic or rubber--either a piece of cracked wiring insulation or gasket--resting on the front valve, which of course is open. As gently as I tried with extended needle nose pliers and a mini hook tool, however, I was unable to extract it, and it dropped into the cylinder. It was between 1/4" and 1/2" long.
While I think it would have been desirable to have extracted it, my thought is that a tiny piece of rubber/plastic will quickly be burnt/melted/vaporized and blown out the exhaust side with no long-term ill effects. But before I put everything back together and try firing up the car, I thought I would seek some reassurance from other folks. I am absolutely positive it was not metal.
TIA and Happy New Year,
B
Old Jan 1, 2005 | 06:08 PM
Jfrahm's Avatar
Jfrahm
Two words: Shop vac. Either that or don't worry about it. If you pull the spark plug you can probably suck it out that way or through the intake port.
-Joel.
Old Jan 1, 2005 | 07:54 PM
Garth S's Avatar
Garth S
Another trick that can work for this is to take a length of plastic tubing that fits through the plug hole, and to the outer end, cut a slot that allows a compressed air line nozzel to fit. Blowing out the tube, away from the engine, creates a 'vacuum' in the tube to lift out debris.
Of course, if air is available, cover up everything open - and blast out the cylinder via the plug hole.
The 'Frogs tongue' approach is to reverse wrap and secure a piece of duct tape around something like a strand of 14ga house wire: with this sticky tip, it can be amazing what will be retreived.
Old Jan 1, 2005 | 11:04 PM
Vlocity's Avatar
Vlocity
I would get it out. Although it would be really unlikely, what are you going to do if it gets stuck under the valve and the piston smacks it?
Ken
Old Jan 1, 2005 | 11:37 PM
heinrich's Avatar
heinrich
928 Collector
Brian it's probably OK but I agree, you really should vacuum it out of there.
Heinrich
