ATF fluid leakage somewhere in right front
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Hey guys, I discovered this morning about a 2 inch diameter puddle of ATF under my 928 when my dad fired it up this morning. The leak appears to be coming from somewhere in the right front where a metal line connects just below the upper radiator hose on the passenger side of the radiator. I know these radiators cool 3 types of fluids and I have ATF also in my power steering. My question is, the line that has the leakage; could that be the ATF line running from the tranny to the radiator or is that a power steering line I see leaking?
Fuse 24 Assassin
Fuse 24 Assassin
can the fitting it's possibly leaking at (I can't really tell unless I remove the upper-radiator hose) be repaired? or does that whole line have to be replaced? If I recall. It's about $130 bucks minimum to replace that line!
The better thing to do is clean the area down with a shot of brake cleaner fluid and a rag - to determine exactly where it is leaking. Yes, it's easier to open the rad drain, and lower the level enough to slide the top hose off.
The fitting is a 32mm gland nut threaded on a 27mm hex compression fitting sticking out of the rad. Hopefully, the leak is due to a slack gland nut. If that's the case, counter hold the 27mm fitting ABSOLUTELY RIGID **- and then attempt to tighten the 32mm. Perhaps, that is all there is to it.
** it's bad news to twist that fitting, or it could cost you a rad ...
Fuse 24 Assassin
Fuse 24 Assassin
great, that's all I need, another $1,400 tagged onto the expense account for that car this month. And, it's been doing so well so far!
