DIY Wheel Alignment Accuracy
If you are using my DIY laser wheel alignment system and start with the caster or camber out of adjustment the toe-in methods may not be accurate. Caster or camber adjustments affect the wheel track and therefore the measurements on the toe-in gauge. To eliminate this problem, make the toe-in gauge after caster and camber adjustments.
Download the latest version of the DIY alignment instructions from my web site for the correct sequence of DIY Alignment. http://members.rennlist.com/captearlg/
If you previously downloaded my site, check the date at the top. Download the latest date, there are many changes.
