Help! Radiator dimension needed
Captain Obvious
Super User
Super User
The bearings in my radiator fan are need of a replacement. As an upgrade I’ve decided to install one large (16”) or maybe two small electric fans. Before I left the house I forgot to measure the dimensions of the radiator.
Can someone post the measurements of the radiator? I need the width and height between the tanks (core dimension) only.
Also, if I decided to install one 16” fan, will that be sufficient for cooling? What is the required CFM to cool the 928s radiator?
Thanks for any info.
