Correct method of entry and exit.
#31
Range Master
Pepsie Lite
Pepsie Lite
Originally Posted by Intrinsicate
Getting in is the easier part, because gravity is working for you, not against you. I find it very to get out without using the bolster of the seat as a leverage point. I wonder how Steve McQueen did it?
I use the "plant and pivot" method to get in, and the "pivot and push" method to get out......
#39
Originally Posted by Ron_H
Let me clarify: I am 6' tall. I will break my leg if I try to first place it into the footwell and then drop down into the seat because it would be wedged between the wheel and the seat. So, I face away from the seat with my back facing perpendicular to the line of travel of the car. I then plop my butt into the seat cushion still facing the same way. I then pull my legs into the car while I rotate my butt by grasping the wheel with my right hand and leaning into the car toward the passenger seat.
If you use the Meguiars Gold Class Rich Leather Spray
![nono](https://rennlist.com/forums/graemlins/nono.gif)
#40
Well, thanks for the suggestions! I tried most of them, just ignoring ones that involved the sunroof, windows or hatch. Bottom-line (no pun intended), if you're over 6', and past the half-century in years, it's a struggle.
#41
What we need is a trapese bar on the driver's entry. Then you can grab the bar, pick up your legs, swing in and drop. Good exercise for those of us who are not in the "younger and/or smaller" category too.
#43
Originally Posted by justin
I always get a running start from the passenger side and slide across the hood, before getting in. While screaming at the top of my lungs. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
I haven't seen a Porsche cape.....yet....
