Where to buy replacement rear quarter window trim?
I need a lower trim replacement piece, for the drivers side rear quarter window. Is there any place that carries these? Either in original aluminum or plastic?
Cottage Industry Sponsor
If the big three don't carry it, you have two options - depending on what's wrong with the old one:
1. If the old one is just faded but not bent, warped, or broken, you might want to look into the Jager Engineering overlay kit - it saves you from a lot of pain and suffering that you'd go through when replacing the original trim piece.
2. If your old trim piece is damaged to the point that it must be replaced, you can ask your local Porsche dismantler or Porsche dealer for a replacement.
