The Door Handle Won't Open-
Someone tried to break into my car and broke the handle mechanism again. Notice my last post on this issue was in 2002, so I now get to skin my knuckles again What fun. And the jerk did it on the driver's side so I have to slide into the car from the passenger side until I get it fixed. PIA if you ask me.
Now why didn't I think of that?? I guess because my car has a hidden battery disconnect switch from the days when some ham fisted mechanic made a mistake running wiring through the firewall and it caused a fire while I was at the Porsche Parade in Florida and had to limp home with a cluster **** of wiring under the dash. I simply installed a hidden switch to bypass the gremlin that shop (whose name shall not be mentioned) was unable to repair. **&^%$#^%&*$!!@!! Grrrr!!! if you want something done right, do it yourself!
The windows are not operative until I enter the car and render them functional.
The upside is that my gremlin, which has become permanent, gave birth to theft control as an unintended benefit.
