What parts are the same for '78 and '95?
Jim B. brought up an interesting question - What parts are the same for '78 and '95 928's? Some that come to mind are possibly the AC expansion valve, sun visor clips, ignition switch, some relays, coolant reservoir cap.
Range Master
Pepsie Lite
Pepsie Lite
The name..........
Range Master
Pepsie Lite
Pepsie Lite
Well, I HATE to say it, but in this case jim, you PROLLY ARE the smartest guy in the room.........
ok..let see...some wild a$$ guesses....rear hatch...door glass...rear hatch glass, outer door handle, lug nuts, window switches, sunroof panel (if the 78 came with them?), door map pockets?
There must be more.but yes...not as easy as it sounds...
edited in.... front and rear side marker lights (US style of course), that chunk of wood covering the fuse panel? side console panels?
more edited in:...how about the rear seat backs?...I know they moved the release from outboard to inboard after 87.but are they moveable side to side.
How did i do?..
Later,
Tom
midlman@rennlist.net
89GT
How did i do?..
Later,
Tom
89GT
Bumper plugs, front bumber tow eye, door lock mechaism parts & handle for sure. all the bulbs in the tailights? grasping at the small and "low profile" parts...- Ruf
Range Master
Pepsie Lite
Pepsie Lite
early locks are vacuum actuated if I remember correctly............
rear hatch is different (indents for rear spoiler bolts) ,glass different color , 1/4 glass DIFFERENT SHAPE , rear seat backs mount differently , window switches different, wooden fuse cover late has plastic pocket for fuse relay sheets, 1/4 marker wiring harness is different .................some I think are correct are lug nuts, some light bulbs ,map pocket *****,heater valve
928 Collector
some light bulbs ,map pocket *****,heater valve, sun visor clips as stated and
oil pan bolts and other fasteners
thermostat
radiator (some, depends on oil cooler)
e-brake handle
hood cable and handle
rear seat bottoms
some carpet (not the loose bits)
seat rails
seatbelt mounting hardware
rear seatbelt panels and roses
map pocket lids, but not the rest of the arm (aperture for switches on later models and angular grilles on earliers)
upper interior trim of door
window rubber trim, but not the large door one
door lock **** interior and backing plate
air vent soft rubber and hard plastic inserts where door meets dash
pedal rubber "928"
gas pedal
footrest
rheostat(one)
some switches but not lights
under-steering wheel plastic or leather trim piece
pod
some stalks
not centre console side peices or door interiors (old ones locked-in and no coin holder)
ashtray (front) and insert
shift pattern insert 5spd
auto shift indicator etc like rubber concertina but not handle
upper trim insert around hvac head
ob has no dash heater temp sens
glove box door and attachments
assuming ob has no sunroof otherwise roof panel interior and sunroof internals
headlight nozzles
How's that so far?
thermostat
e-brake handle
rear seat bottoms
seat rails
pedal rubber "928"
gas pedal
footrest
rheostat(one)
pod
some stalks
headlight nozzles
How's that so far?
Here's some differences: in the '95 the driver is younger and drives faster, and the passenger has bigger fake *****!! The grin on the driver is the same.
