What parts are the same for '78 and '95?
928 Engine Re-Re-Rebuild Specialist
air filter, oil filter, jack, engine cross brace, carpet set, floor mats, fuse panel cover (wood), hood, heater box, hot water shutoff valve?
Hood shocks, hatch shocks, tensioner roller, hood emblem, interior light bulbs, wiper blades, steering rack boots, interior lights, wheel well covers?
big dave....."air filter, oil filter, .......nope jack, engine cross brace, .....nope carpet set,.... nope floor mats, nope...fuse panel cover (wood), ....nope (different holes for squirters)hood, ....nope heater box, hot water shutoff valve?
Hood shocks, hatch shocks, tensioner roller, hood emblem, interior light bulbs, wiper blades, steering rack boots, interior lights, ....nope vary greatly wheel well covers?
rear view mirror?
Door panel clips?
Little plastic fasteners that hold the clear "928" or "GTS" panel at the bottom of the door opening?
Button covers on center console for window switches?
Door panel clips?
Rear "bearing body" in Manual gear shift linkage, Most if not all of the rear hub carrier assembly except the hubs and bearings, rear upper control arm.
Jon the rear uprights are different (brake mounting points) , the lower suspension arms have more reinforcement , bearings are the same , upper a arm the same , the big crossmember is different (trans mount locations exhaust hanger bracket holes) .
