928 Forum 1978-1995
Sponsored by: 928 Specialists
Idle surge after Plug Change
Old Oct 21, 2004 | 05:47 PM
dave1200's Avatar
dave1200
Default Idle surge after Plug Change
Hi all. I have a strange question.
On the 88 32 Valve engine. It had a slight idle surge after it got to temp, not bad, but hunting a little. I put new plugs in, and it started surging very fast up down up down. Sounded like someone was in the car reving it. I triple checked all the vaccume connections to make sure I didnt knock something off.
Thats the only change I made:
The plugs I removed were all carboned up.
Why would it do this just because of a plug change? It didnt do it while it was in gear. only Park or Neutral. The car was ALOT morte responsive with the new plugs
Thanks for any insight to this strange problem.
Dave
Old Oct 21, 2004 | 05:55 PM
Gretch's Avatar
Gretch
Range Master
Pepsie Lite
You have either a vacuum leak or your idle stabilizer is gummed up. Prolly the idle stabilizer. Do a search on it and give it the WD40 treatment......
Old Oct 21, 2004 | 05:59 PM
whall's Avatar
whall
Dave,
I had the exact same thing happen to me. I asked here and was told to check vacuum. Bought a vacuum tester, found the leak way under the back, replaced the hoses and fixed the problem.
dave1200's Avatar
dave1200
where exactly is teh idel stabilizer on these cars? WHat does it look like? What general location would it be?
Old Oct 21, 2004 | 06:04 PM
marton's Avatar
marton
take a carefull look at any vacuum lines near theactual plugs, maybe one got knocked off during the plug change?
Old Oct 21, 2004 | 06:08 PM
Gretch's Avatar
Gretch
Range Master
Pepsie Lite
here is a picture. it is under the intake manifold. DO A SEARCH.
Old Oct 21, 2004 | 06:10 PM
dave1200's Avatar
dave1200
Thanks...got it!!!
Old Oct 21, 2004 | 08:56 PM
dave1200's Avatar
dave1200
I put the old plugs back in..no more surge. The new ones were NGK's ????
Very strange.....
Old Oct 22, 2004 | 11:42 AM
Gretch's Avatar
Gretch
Range Master
Pepsie Lite
I will say that is strange.................Try AC platinum plugs..................I have had great results with them. Bosch are also quite good, and actually cheaper. This is because the platinum center piece is considerably smaller......
Old Oct 22, 2004 | 11:54 AM
Mark's Avatar
Mark
Recent thread on spark plug selection - Others (like the AC's mentioned by Gretch) are ok, but general consensus - Bosch Super's (STAY AWAY FROM THE MULTI ELECTRODES!).
It could be that the NGK's are the incorrect heat range....AND - there is likely an underlying reason that the old ones were "carboned up"
