928 Forum 1978-1995
Sponsored by: 928 Specialists
Cold Start Pic
Old Oct 20, 2004 | 08:55 PM
PatrickP's Avatar
PatrickP
Default Cold Start Pic
Anyone know where I might find a picture of a "cold start valve?" I have the manuals on CD but am not sure it shows what I would be removing or replacing. Looking on the 928 Int'l site hasn't given me anything. REGARDLESS, I think I may need to replace one, the manual doesn't seem to indicate it is too complicated to do so and I want to give it a shot ... assuming the '85 has such a valve! Thanks to all in advance.
Old Oct 20, 2004 | 09:04 PM
Jim bailey - 928 International's Avatar
Nope........no such part on your year . Instead the fuel injection knowing the engine is cold injects extra fuel and the idle stabilizer valve controlled by the brain maintains engine speed.
Old Oct 20, 2004 | 10:13 PM
PatrickP's Avatar
PatrickP
Thanks, Jim! Does this mean that if my car runs a little rough and needs some coaxing for the first 60 seconds or so when its cold that I may need to check out the idle stabilizer valve? Thanks again!
Old Oct 20, 2004 | 10:34 PM
jpitman2's Avatar
jpitman2
More likely a temp sensor problem - unit or wiring. They usually run resistance of ~3000 Ohms cold, going down to ~250-300 ohms hot.
jp 83 Euro S AT 48k, with minimal electronic gizmos to worry about.
