Fuel Pump Check Valve Replacement
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Has anyone made a website on how to replace a fuel pump check valve? I've never done it before since my car has a hard starting issue when warm and usually I have to step on the gas pedal a little to get it started. When cold it fires right up after 1-4 cranks.
If no site on how to do it, how do I go about the replacement, if anyone knows...
Received 1,624 Likes
Fuse 24 Assassin
Fuse 24 Assassin
Thanks worf, but if its the opposite, I'm sorta at a loss of thought for troubleshooting what it could be? faulty damper and regulator maybe????
Do you have any other symptoms? What's your gas mileage like? Once the car starts when warm does it idle well? Or does it die immediately if you don't give it partial throttle? Any other info will help narrow down the list.
I've got the same issue...I've replaced the MAF (good deal on an E-bay new item), the temp II sensor...just because it's cheap and the other was old, the fuel distributors and dampers and still sometimes have the problem.....new check valve is on the work bench for next time I'm in there!
The hard to start when hot is typically not a big problem....just annoying and a bit embarrassing when you have to crank the car so many times to get it to fire!
My idle is steady and the car give me no grief when it's started
Fuse 24 Assassin
Fuse 24 Assassin
my idle is a little unsteady on a start but will steady out when warmed up. Same thing after driving then parking; then coming out to restart it in 30min- 1 hour.
Sorry I didn't respond last night. I was watching the SOX own the Yankees...
Mileage for an 87 should be in the 19-21 range on the highway. 16 - 19 for mixed driving. Maybe a bit less if you have a right-foot deformity. If it is consistently 15,14,13, or less then it's too low.
Have you tested (can you test?) the resistance of the TEMP II sensor?
As for other troubleshooting items:
These are the obvious ones:
Fuel Pressure
Fuel Pump Power
Intake/Vacuum leaks
Idle Control
Not so obvious:
O2 Sensor
Tank venting system
Final stage ignition
Fuel Injectors
What does the Fuel Pump sound like? A light buzzing that is constant? Or a loud buzzing? Or a buzzing that gets louder with the throttle? (Kinda like a stereo badly-suppressed?) Does the warm start problem happen at all ambient temps? Have you looked at all of your vacuum lines and checked to make sure that they are correctly attached to the correct gizmos?
Has this condition come on gradually? Or suddenly? If the latter what was the last thing on the car that was touched?
Gas mileage is great!!!
Fuel Pressure
Fuel Pump Power
Intake/Vacuum leaks
Idle Control
Not so obvious:
O2 Sensor
Tank venting system
Fuel Injectors
