Another SC 928 hits the pavement
#76
Sharkaholic
Originally Posted by heinrich
Wow. I guess some posts here must have been deleted? I don't see the original "gripe" message. I'm sorry you guys went through this. Apparently the kit works well but needs some adjustment, and clearly Tony has done an almost factory-quality installation of it with some innovative improvements. Andy I'm hoping my kit doesn't have these issues .... are all the shims included and are the parts correct, ie does the snout support I have, fit?
#77
928 Collector
Both. And Sharktoberfest and other things ... I was there for a week, Palm Springs and Disneyland with friends also. Actually I've been having a lot of fun driving the '85 lately too
#78
Range Master
Pepsie Lite
Pepsie Lite
Tony, re the broken bolt....FWIW, I had torque specs on the bracket mount bolts, I used them and broke a bolt anyway. I purchased another at the hardware store and it torqued down just fine. The torque specs for bolts of a certain size, thread and hardness had be had quite easily. My torque wrench came with a chart that is a nice cross check refernce.
#80
Tony,
Any chance you could give us pictures and a description of the modified shroud?
Originally Posted by Tony
. . .Some highlights and features.
Stock cooling fans with a modified shroud that allows the assembly to be removed in no more than 5 minutes. Removing the various oil and tranny cooler lilnes is no longer required. That one mod alone has saved me hours already!
#81
https://rennlist.com/forums/showthre...ghlight=shroud
I posted on it about 2 months ago. It works great. I have my shroud out in 2 minutes. No kidding.
2 bolts that hold it on...two fan wires and connectors out of the way...and the airpump hose bent back.
Up and out it comes.
The link details it better.
Two cautions.
1) be sure you secure your airpump hose to the inside of the engine bay as the edge of the shroud use to help hold it back. it WILL hit the fans if you dont. Becasue of this you may have to add appx 2-3 inches of extra hose to the end of the airpump hose so it reaches the filter in the shroud.
2) make sure the fan doesnt interfere with the oil cooler lines on the driver side on the plastic end tank.
A given and as always, watch your fingers on the metal tabs that secure the wiring as well as the possibility of the fans turning on if your working on it
HTH
Two cautions.
HTH
