Ott X-pipe came yesterday
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
anyone have the URL to the OTT X-pipe's website? Last time I remember finding it, it was still under construction....is it up yet??? is OTT a Rennlister???
Andy
Andy
Range Master
Pepsie Lite
Pepsie Lite
Originally Posted by Old & New
Any Ott pipes up here in New England? I'd like to check one out, too. If the car could squeak by on the yearly motor vehicle inspection, maybe I'd like to lose the cats. No friggin' way I'm spending thousands on a custom high flow cat system if it would pass without them... sorry, greenies, go picket a powerplant - or a volcano.
OLD, I have the 89 GT stock exhaust with the RMB. It is on the fuzzy edge of loud. My inspection resulted in the car being put on the lift to look the exhaust system over....It passed, but I would have been bounced with no cats.....On top of the fact that I cannot believe that I would find the noise tolerable if it was any louder. Under WOT it wakes the dead.......
You could install an X pipe with CATs. It would not cost that much more and the HP loss is almost negligable if high flow CATs are used (Random Technology shown). By ceramic coating the X pipe the heat from the exhaust will make it to the CATs and they will operate efficiently.
Fuse 24 Assassin
Fuse 24 Assassin
what's the diameter of the OTT X-pipe? is it 2 1/4" like the factory???? I wanna get one but like to keep my secondary mufflers and incorporate the RMB still.
Fuse 24 Assassin
Fuse 24 Assassin
wow I really really want an x-pipe now and with a 928 Intl. RMB I can't wait to wake the neighbors! Kinda like a rooster at about 9:30 at night...and about 928 of them.
I will be running Bullet Mufflers, p/n 212161, because they fit on 2.5" pipe, fit under the car, and flow well. The 2.5" pipes will go all the way out to the rear of the car. All pipes will be ceramic coated prior to the final installation. I understand that these mufflers produce lower frequencies and not the high frequency tinny rapping type of sound.
Deer Slayer
Hm... my X-pipe came without gaskets (no surprise really). Can I fabricate some out of exhaust gasket stock? Which thickness should I use? Or is there a special Porsche gasket that I MUST use for some quasi-mystical reason?
Thanks in advance...
