WTB Cam gear & oil pump gear for my 86 shark-Anyone?
Worf and Carl were over last sunday to help tear down my 86' 32v, thanks again for your help guys! During the teardown we found the usual stuff bad, a dry tensioner with a little grease in it, over tightened timing belt with a bunch of missing teeth, worn cam gears, oil pump gear, and crank gear. The valvetrain had slipped about 2 teeth. It was running fine when I shut her down, but it had lost power from 3-5k RPM.
The quest for parts begins now. Anyone have some spare cam gears or other TB parts in nice shape? I am moving right now so the assembly process has been delayed. The car is now residing in Peterborough for the finishing of the project, just had her towed over.
Thanks Thaddeus and Ron, I am trying to finish moving so I can get back to the car. Did your cars slip any teeth? Someone said that if it slips 3 teeth then you have some bent valves, does anyone know the facts on that statement?
Update: I ordered all the parts except I could not get the cam gears or oil pump gear second hand. I wanted to put it back together on a tight budget for this year, otherwise I may be waiting a couple months longer.
I may have the used cam gears at the shop. There is a possibility I have the oil pump gear, too. Can you wait 'til the weekend to hear from me?
Sorry, I am in Baton Rouge right now. The parts are in Atlanta.
