928 Forum 1978-1995
Sponsored by: 928 Specialists
Front tires inside tread worn
Old 09-15-2004, 08:22 AM
Rick3452
Rick3452's Avatar
Question Front tires inside tread worn
I have an 82 5 speed with inside tire ware. Is there an adjustment that a local alignment shop can do. Thanks for any info...
Rick
Old 09-15-2004, 08:34 AM
Ispeed
Ispeed's Avatar
Welcome to the club, Rick. I think that is due to toe out from a typical not-right alignment that doesn't settle the front end before adjustment. If you do a search you will find a lot of previous threads on alignment.
Carl.
Old 09-15-2004, 09:19 AM
bgrabner
bgrabner's Avatar
I have the same problem on my 87 Rick - the front tires are toe out (I think that is the term - they are trying to go in separate directions instead of tracking parallel). You are going to need to find an alignment shop that will align all 4 wheels while the car is resting on the suspension - it cant be lifted at all or the alignment won't be accurate. Good luck - a lot of shops won't do this...I haven't found one yet myself :-)
Bill
Old 09-15-2004, 09:54 AM
Erik - Denmark
Erik - Denmark's Avatar
Rick,
Yes that's due to bump steer and bad alignment
The car must not be lifted during the alignment procidure because the toe-in/out is changing drastically with the hight (suspension)
See my article in 928 Forum magazine # 4 or study Earl Gillstrom home page - bouths will give you the answer
Kind regards from Erik in Denmark
Old 09-15-2004, 11:26 AM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
Check out Earl Gillstrom's web site - http://members.rennlist.com/captearlg/
Old 09-15-2004, 11:38 AM
heinrich
928 Collector
heinrich's Avatar
Very common. From lifting the car and aligning immediately, then when the suspension settles the car looks like a squatting duck.
Old 09-16-2004, 07:46 AM
Rick3452
Rick3452's Avatar
Thanks to everyone! I have an appointment with Musante Motor Sports in CT. in a couple of weeks.
Thanks again...
Rick
Old 09-16-2004, 11:23 AM
WallyP
WallyP's Avatar
Make VERY certain that they understand that they CANNOT lift the car to check the suspension or to zero their equipment...
Old 09-16-2004, 11:28 AM
Scott M.
Rest in Peace
Scott M.'s Avatar
Rick;
Musante is Dave Lloyds outfit, you should be in very capable hands there. Just don't let him take it to the tracks.
Scott
Quick Reply: Front tires inside tread worn
