GTS Door Sill Upgrade
Hi Gang,
Just wanted to share my experience with my easy to install GTS upgrade. The complete procedure for both sides took about 2 hours and looks (I think) pretty cool. I noticed at the Wichita KS convention that some owners painted the background of the clear plastic in the door sill. The idea is pretty good but I wanted to "personalize" my car a little bit beyond paint. I found the lumi-line homepage and ordered 2 EL 12 Volt light strips (40 cm long by 3 cm wide) in blue/green color. Total cost $25 incl. shipping. 1. These are the 2 EL light strips with their AC converters https://rennlist.com/forums/members/...el-strips1.jpg 2. Door sill removed, I actually shortened the light strip about 1 inch to make it fit between the 2 front clips nearby the clear plastic "GTS" letters. Mazke sure that you seal the end that you cut to prevent moisture from entering the light strip! After I was sure that the area behind the GTS letters was completely covered, I glued it into position (comes with self-adhesive tape on the back). https://rennlist.com/forums/members/...el-strips2.jpg 3. Routed the really thin wires and installed the door sill again (after cleaning). That's how it looks without being connected to the interior lights. https://rennlist.com/forums/members/...el-strips3.jpg 4. Routed the wires inside the car and connected them to the light that sits below the glove box. It uses very little energy and I think it is a really cool and stylish upgrade to the otherwise (I think) plastic door sills. Lumi-line sells the light strips in differnet colors and I'm NOTHING to do with the company. Just wanted to share my experience! https://rennlist.com/forums/members/...el-strips4.jpg Sorry the picture is slightly out of focus but I was to lazy to get the tripod out! |
That is too cool!! Great job.
that would like nice in red... good idea, and functional also!!!
Wow Schocki,
Looks cool, and a very original idea. Mods like this are fun because they are inexpensive, non destructive, and you can just turn it off if you wish. My clear 928 sill plates are pretty scratched up. If I can get a new set, I will give your idea a shot. Thanks for sharing, Mike |
Very nice... I almost wish I had seen this before I went with my Jager metal inserts for my doorsill. :thumbup:
dam nice,,would be really cool if it changed colors,,,or went from blue to red if you leave keys in egnition or head lights on
nice. next project...
Looks very good; great idea.
Affengeil!!! :jumper:
Very nice!
Shock,
Nice job! Now for the motor mounts??!! |
We had been tossing around the idea of upgrading this on Socal and someone mentioned lights but no one knew of these babies. That is the way it should have been done in the first place. Did you hook electric into the door plunger? Could you do some electrical detailing for us guys who dont know how to do electrical?
Very cool!
Nice one Michael!
Your the man! Got to do mine in red. Best, Roger |
I like it!
So it only illuminates when the door is open? |
