928 Forum 1978-1995
Sponsored by: 928 Specialists
Hood Pad Alternative
Old 09-08-2004, 03:07 PM
Randy V
Randy V's Avatar
Thad / Ken - Hah! I never noticed it was backwards!
Thanks for the reversed gif Ken - I've changed my sig to use that one.
Good points Steve - the hood insulation is for sound and heat 'attenuation', not reflection back into the engine compartment.
Old 09-08-2004, 03:33 PM
Tony
Tony's Avatar
Originally Posted by redidrum
Gents,
Check out http://www.reflectixinc.com/
Todd at http://www.928world.com/staticpages/...40225195815926 used the Reflectix material and so have I on my car. I used high temp. contact cement and two layers of the stuff. Hood stays cooler and looks nice. Don't know exact specs., but, mine works very well for 5 months so far. .
Buy it at Lowes for $25.00.
Ron
Im sure it looks good and it really sets off the engine bay but why insulate your hood?
You want the heat OUT of the engine bay, not kept in it. If your worried about the heat damaging the paint, uh, the inside of the engine bay is painted with the same paint as the outside and its OK, as is the paint around the "foamed" area on the underside.
I would leave mine bare if i could, but getting a nice look after you get the glue and crap off is impossible. When the time coems here int he next week i will use the stock stuff again or a similar type foam product.
Old 09-08-2004, 05:03 PM
Steve J.
Steve J.'s Avatar
Tony - the rough side of the Armaflex would look great with your black supercharger. The Armaflex looks blacker than the oem foam (which is kind of dark greyish black). This shows the difference with the smooth side out or the rough side out. Smooth side may be easier to wipe off, but it also shows nicks or fingerprints more. Since the foam is closed-cell, it's not going to act like a sponge with the rough side out. And it's more attractive.
Old 06-27-2021, 09:57 PM
Tony
Tony's Avatar
hmmmm....
Quick Reply: Hood Pad Alternative
