REbooting Computer(improperly)?
Hi there. I bought a new battery for the car. Installed it and just went off on my own way. What I've noticed is less ooomff especially at low RPM's. I did not let the car idle for 10 minutes or so prior to taking off. I've read that the computer requires a few minutes to get to know itself again . Is this the problem! Or what I've heard about reboot time is Malarcky? Hoping that this is a simple issue. Mike Thank-you for any info.
Mike,
It will take several minutes of running under a variety of conditions for the LH ECU to re-adapt to your car. This is mainly is compensating for MAF ageing. The worse the ageing, the longer it takes.
Chronic Tool Dropper
Pretty sure his doesn't have one of those, at least from the factory.
Mike--
Mine seems to learn "differently" depending on how I happen to drive it following reset. I unhook the ground strap whenever I'm away from the car for more than a week, and this year it's been a fairly regular exercise.
Learning: I suspect that the first minute or so is wasted since the oxy sensor needs to heat up. After that, if I immediately drive it briskly for a while, the later response seems to be better than if I am ultra-conservative during that initial drive.
John--
For how long does the controller learn or adapt after a power-off reset?
Mike--
John--
The S4 and later cat equipped cars have two forms of adaptation -
idle adaptation (which is quite quick, about 5-10seconds) and O2 adaptation which takes several miles of driving under varying loads and rpms to fully adapt the LH ECU.
Mike--
John--
Mike--
John--
