Ford Fuel Injectors
Ford Fuel Injectors
My '88 S4 with 112K on it has been idling rough and developed a slight stumble upon acceleration. I've run a few bottles of injector cleaner through but it hasn't seemed to help much. I was going to have the injectors cleaned but at the cost of the Ford injectors I'm thinking of just going with those. Someone mentioned that with those it runs a bit rich at idle. Is this true? If so am I going to have problems passing emissions tests?
As I understand it the 19# injectors are the ones to get and I'll need the spacers and o-rings from the old injectors (if I can get them off). Correct?
Andy,
It dosen't seem to me that the Ford 19# injectors would run rich at idle. I use the FMS 30# on my supercharged S4 and even they aren't too bad.
HTH,
Andy K
HTH,
Andy K
Range Master
Pepsie Lite
Pepsie Lite
ditto.
I have installed the Ford 19# on my Euro MY87 928S4 (No O2 sensor) it ran fine.. You will need the O-rings and they fit just fine. The Ford injectors could be had for around $200/set of 8. Good upgrade.
Location: Seattle - it's not Hell, but you can see it from here!
the spacers don't really matter, but are you really going to use 16 year old seals?
I bought brand new seals specifically for the ford mustang, and I have not had any problems getting the injectors to mate to the fuel rail. Why do people suggest using the old seals?
Andy- How much are the Ford injectors? There's a guy in Michigan who rebuilt/flowed mine last year, and he charged me $16 each to do it! He's not a Rennlist sponsor as far as I know, so PM me and I'll give you his name.
A great source of information on injectors is Rich at Cruizinperformance. He's in Michigan, but I don't have his phone number.
N!
N!
How many pounds are the stock injectors? and did they change from year to year?
SilverSFR
SilverSFR
SilverSFR,
It changed from year to year.
85-86 US = 24# high impedance
S4 = 19# high impedance
up to 84 US = low impedance. I can't remember the #/hr but they are pretty big.
HTH,
Andy K
HTH,
Andy K
