Timing Belt Trick
Subscribe
Jul 17, 2025 | 12:21 PM
Wondering if others have seen this video and any would like some comments about it:
Reply 5
Jul 17, 2025 | 12:43 PM
Yes it works
Reply 0
Jul 17, 2025 | 05:16 PM
Very cool! I love stuff like this.
Reply 1
Jul 17, 2025 | 06:13 PM
if you're running the factory tensioner make sure to back the tension off during the process. with the PK Tensioner the tensioner itself should accommodate the belt run change, but the factory tensioner will not compensate.
Reply 2
Jul 17, 2025 | 06:50 PM
I was told to only rotate the engine clockwise looking from the front. No going anti clockwise.
Reply 0
Jul 17, 2025 | 10:27 PM
it will be OK to turn the engine either direction for a short bit of adjustment.
NOTE dont make the belt tension too loose as turning it could make the belt jump
Reply 0
Jul 18, 2025 | 11:54 AM
It worked satisfyingly well when I didn’t spot a sprocket moving by a tooth when I changed belt earlier this year.
Reply 0
Subscribe
