4 piston caliper scraper ring removal
I'm in the middle of disassembling a set of 4 piston calipers off of an 86.5 for powdercoating. I've got everything removed except for the scraper rings. What is the easiest and least destructive way to remove these scraper rings? Also, can I purchase a kit to replace all these seals and scraper rings?
Thanks, let me know where you get your replacement seals. I may be in the market for some. So far I've heard the dealer is big $$ and I may have to go to Brembo to get just the seals as the dealers only sell kits which include pistons and seals together. Good luck!
