Auto.Trans. Pan pressures.
Hi there. Could anyone tell me what the Auto Transmission Pan. experiences in oil pressures? And, is there by chance some sort of anomoly in the valve body that can give you an overpressurization situation that can give you oil blowby through the pan gasket? Thank-you for any replies. Mike.
The Transmission is vented to the atmosphere through a case vent and through a reservoir vent. One would suppose pressures might be present if both vents became plugged, but that's not the case in my situation. I've looked there.
