S4 fan speed modulation
Range Master
Pepsie Lite
Pepsie Lite
other than the various sensors triggering cooling fan operation, does the fan control module vary the speed of fan operation? IE are there more than "on" and "off" modes?
WSM page for 87 and up says :
"The output stage recieves a square signal from the control unit. The output stage contains 2 mutually independant output-stage modules with separate protective circuits: each module controls a separate cooler fan.
If a fault occurs, the cooling-air flaps are opened to 100% and the intact fan operates at full speed, while the faulty fan is switched off. A check is made every 20 seconds to ascertain whether the fault persists"
The fan voltage is variable depending on the water temp and the freon , and it's simple on or off dependant on the transmission temps for auto cars.
There are 3 speed settings.....
Picture of the 3 function charts:
![](http://members.rennlist.com/jayc67/freon.jpg)
![](http://members.rennlist.com/jayc67/water.jpg)
![](http://members.rennlist.com/jayc67/transmission.jpg)
I would have to look it up again. But up until the GTS (year?) the final stage (under the hood) oscillated the fan voltage which would give one the impression of more than three fan speeds.
Originally Posted by ErnestSw
IIRC there are three fan speeds available through the controller. There is no continuous variability.
I would tend to believe that there are really only three speeds.......although the fans take a few seconds to ramp up or down between those speeds, hence the illusion of continuously variable speeds across a given RPM range.
Range Master
Pepsie Lite
Pepsie Lite
Jayc67,
Thanks, and facinating......
What effect does the intake manifold temp sensor have? is the output variable for that sensor too?
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
I think the intake manifold sensor acts like an on/off switch for the cooling fans and my impression is that it's in parallel with the circuit, ie. it only tells the fans to run (at low speed) after the engine stops if the temperature is above a given level. As it's wired from the factory I don't think it could be usefully modified for increased cooling while the engine is running.
Range Master
Pepsie Lite
Pepsie Lite
My best answer is I don't know. Our cooling systems are different in that you have (or had) slats and you don't have the recirculation system. It's possible that my system goes through two speeds after I turn the car off, but if it does I haven't noticed it.
Are you hunting down a problem?
My 87 S4 also goes through 2 speeds when shutting down if I really het it things up, and that matches with the coolant temp function chart above. I also have an A/T so that might contribute since there is a function for trans fluid temp as well. Looks like there is a step down from approx 10V to 8V as the coolant temp drops.
The manual I have does not mention any of the more advanced functions Ernest has. My books are current through the '90 model year so I can't comment on changes made after that.
Range Master
Pepsie Lite
Pepsie Lite
I have changed out the stock the fans on my car because of the imposition of the blower and air box immediately behind the radiator. The kit uses 4 smaller fans mounted in pairs on either side of the airbox. Additional air flow can be induced with a large single pusher fan in the front. Choosing how to wire the fans requires I understand how to diagnose the fan control functions. I just wanna know what I should be looking for, (and up till now have been to lazy to RTFM...........need a "********" Icon here)
The drivers side fan seems to have always come on first on my car, but that is not consistent with the info jayc67 posted about the fans working in unison, with failover mode defaulting to 12 volts for the working fan. However, when I close the intake plenum sensor, both fan circuits operate. Jayc67 says his fans step through two speeds before shut down (with the key off, ie plenum sensor driven operation). I am in learn mode........That is all that is going on...
BTW, anybody here ever try waterwetter of the NAPA brand "enginekool"?
Range Master
Pepsie Lite
Pepsie Lite
That is interesting....so the plenum sensor does not cause the fans to run at full capacity.....ie they don't get 12 volts................oooooookaaaaaaay....
Range Master
Pepsie Lite
Pepsie Lite
Originally Posted by Old & New
I believe there was a change to the latest controllers that allowed the fans to run at full battery voltage, as opposed to capping it at 12V.
