928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine conversion
Old Jul 12, 2004 | 04:20 PM
Wild Bill's Avatar
Wild Bill
The Chevy LS engine does not fit... problems with the sump, kicked out pan rails and the motor mount location, but the LT1s fit quite nicely and is recommended by Renegade Hybrids.
Don't know that Northstar would fit, but while we are talk'n Frakenporsche, what about doing an old bugger all aluminum big block Chevy? About the same weight as the original, but talk about SCARY fast!
Old Jul 12, 2004 | 05:02 PM
John S.'s Avatar
John S.
WB, I'm no muscle-car expert, but aren't those aluminum big blocks hard to find, ergo expen$ive?
That's too bad about the LS engine, but an LT4 maybe...
Old Jul 12, 2004 | 05:04 PM
John S.'s Avatar
John S.
Oh, and in reply to an earlier post, I'm not doing the project for resale. I know I won't get the $$ out. I just want to enjoy a (more) reliable, fast shark. Also, the unique factor is fun too.
Old Jul 12, 2004 | 05:13 PM
glenn faken's Avatar
glenn faken
john
check out speedway motors. they were selling new northstars for 3000.00
glenn
Old Jul 12, 2004 | 05:50 PM
John S.'s Avatar
John S.
Glenn,
Thanks. I took a look. Sure seems like a good deal, but the new engines are from the XLR/SRX - ready for RWD, while the ones on speedway's site are the FWD-configured units. They say they can be converted, but I imagine there's a cost involved in that.
Old Jul 12, 2004 | 06:07 PM
918-S's Avatar
918-S
I went way out of my way to use a 928 motor in my 914. The chevy or any conversion you do will work but you have to ask yourself.....Why?
The 928 motor is shrouded in mystery. If you spent the same money you will loss on the conversion and used it to learn how to hop up one of the most well engineered German V8's in the world, you would not only learn something you'd realize what a shear terror you have at the command of your right foot. The most rewarding part of the victory you will achive is the stories you can tell about the journey.
Old Jul 12, 2004 | 07:23 PM
goliver's Avatar
goliver
A Devek stroker would be a total rebuild and some big numbers HP/TQ.
Old Jul 12, 2004 | 07:44 PM
jayc67's Avatar
jayc67
Spend the money it would take to do the conversion on a nicer example of a 928, lower miles etc, and don't worry about it. If you start with a solid example, the ongoing maintenance isn't that big a deal, just don't start with a damaged engine to begin with if reliability is #1 to you.
