Atf
Having just dealt with the transmission-pan gasket leak, I now have to replenish the thing with ATF. Anyone know how much I'll need to add after the thing sat for a week with the pan off, but didn't touch the torque convertor?
I'm not sure that I have......... what I've done is to build a cork-gasket to fit between the original and the transmission casting. We'll see. But I have to put the ATF back to see if it stays....
This is getting silly!
It still will not seal around the transmission pan gasket!
I took a straight-edge and found that the inner edges of the middle-bolt curved portion of the gasket face, are higher than the same relative portion on the front/back face(s).
Can this be right? It sure doesn't look right, but it also does not look like something that could get "altered" either.
WTF!!
WTF!!
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
WTF!!![grr](https://rennlist.com/forums/graemlins/cussing.gif)
WTF!!
Does the pan fit snuggly without a gasket, or is there an obvious 'high' spot for example?
One thing to try possibly is to make a "gasket" out of modeling clay/'play dough' stuff - and lightly install to get an impression of the contact surfaces: more precisely, the lack of contact. Might tell you something useful ....
The leak seems to be originating at the passenger-side front corner. I have turned the edges of the bolt-flanges down, and the leak is diminished but it still persists.
Fleet of Foot
Brian,
Are you sure it is the pan leaking?? I just went through an ordeal with my beast & the leak I had was due to there being no O-ring around the kickdown cable insert into the tranny. The kickdown cable is right in that area you say is leaking... a new O-ring solved my problem. Just a thought!
Brian get a hydraulic jack and a small piece of 2x4. put it under the pan on the area where it is leaking- with the car in neutral or in gear wait for the leak. Then start adding pressure to the pan. If the pressure from the wood does -not slow or stop the leak I believe you do -not have a gasket problem. Something else is mysteriously wrong! Good Luck! Mike
Good Idea...... Mike! That's next for the week-end.
Bill, I checked all the other fittings and stuff. No other leak sites found afre brake-clean spraying the whole area. You can actually see the ATF start to seep at the gasket/tranny interface if you lay there for 2-3 minutes with the engine running.
Is that the same piece of 2x4 and jack used in your now famous and unmentionable named method for_______-___
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
