928 Forum 1978-1995
Sponsored by: 928 Specialists
MAF conversion from AFM
Old Jul 11, 2004 | 10:59 AM
toofast928's Avatar
toofast928
Default MAF conversion from AFM
Now that I have installed a Euro intake power has increased but could use more top end. Split Second has a "signal controller box" and software to convert AFM to MAF. Anyone tried this?
Old Jul 11, 2004 | 03:12 PM
2V4V's Avatar
2V4V
Tony,
If you are still running L-Jet, then the S/S product will not work for you - unless they've introduced something new in the last coupla months.
The AFM works on a different voltage scale than the S/S product is able to output. Read the detail stuff in their website and you'll see what I mean.
I'm almost done with my AFM replacement solution- I lost a couple of weeks with my welded camshaft failure.
Greg
Old Jul 11, 2004 | 03:28 PM
PorKen's Avatar
PorKen
Inventor
John the "Bastard" used Split-Second's programmable controller (not the one with the ***** the 944 guys use) on his twin turbo. He mentioned it takes a good amount of tuning to set it up.
The problem is the L-Jet uses 0-8v so the simple controller, which only adjust 0-5v, won't work.
I ran across this aussie DIY box, which when available, should be less than US$100 with it's controller: Jaycar.au | Digital Fuel Adjuster
It supposedly can do 0-5v, 0-12v, or even 0-1v (oxygen sensor) conversions.
Old Jul 11, 2004 | 04:18 PM
2V4V's Avatar
2V4V
Addendum -
If you do the MAF conversion, it looks as though they have a programmable converter that should work. Forgot about that one.
But, you can only do MAF, and it's calibrated to their meter (read: you're stuck with S/S meters, which do not give a great performance on the flowbench).
Just depends on your time/$ equation.
Greg
Old Jul 11, 2004 | 10:36 PM
toofast928's Avatar
toofast928
We need to use the S/S controller box and R4 software. I called S/S about a month ago and this is what they told me: They have a conditioner box for L Jet 8 volts. Need the software to fine tune over the entire RPM band. I far as I can tell the system is not calibrated to S/S MAF. In fact I was going to use Vortech 80mm with Ford's MAF electronics.
Thanks John for the link. But imagine if we could adjust air/fuel ratio on the fly!
Guess this is my winter project.
Tony
