Temperature sensors
Does anyone know if it would be possible to remove the inside and outside temperature sensors, and revert the climate control system to manual operation?
I know if you remove them the system will go full hot. Most people that have trouble with there climate control either have control head problems, a bad out side tempsensor or no freon.
Chronic Tool Dropper
What exactly do you feel the controller should do in "manual" mode? There is no provision for modulating hot water flow from the temp slider; Heater valve is operated by an on-off solenoid, and you can see that function by just disconecting either or both of the temp sensors. Valve is either full-hot or no flow at all. All other functions are already manual.
