928 Forum 1978-1995
Sponsored by: 928 Specialists
Alternator Installation?
Old Jul 8, 2004 | 07:11 PM
Carson Kit's Avatar
Carson Kit
Question Alternator Installation?
Hi-
A few weeks ago I took my alternator off of the '82 5 spd. to get it rebuilt.
Now that it is back from the shop I can’t remember where one of the wires goes.
I know where the thick red cable connects, but can’t find out where the small thin one with the ring connector goes.
I have searched the archives, the net, and looked in the workshop manual and can’t find the answer.
If someone could tell me where it goes or possible post a picture, I would greatly appreciate it.
Best Regards,
Carson.
'79 White/Cork Auto
'79 Red/Black 5 Speed
'82 Black/Black 5 Speed
Old Jul 8, 2004 | 08:15 PM
Garth S's Avatar
Garth S
If the alt is a Paris-Rhone, like the one sitting on the floor beside my '80, there are 3 connection points. Sit the alt in its mounted position; this puts the B+ (13mm nut) at the bottom, or 6 o'clock when looking at the rear . This is for the large power cable. The other two posts are at 4 and 5 o'clock, with 8mm and 10 mm nuts respectively. The wire you want to connect to is at 4 o'clock - 8mm nut - ties to the voltage regulator.
If you still need a pic, I can get one in the AM.
Old Jul 8, 2004 | 09:00 PM
Carson Kit's Avatar
Carson Kit
Garth-
Thnak you very much for your help.
You are correct, it is a Paris-Rhone.
Thanks to you clear description I will not need the picture.
Thank you again!
Carson
Old Jul 8, 2004 | 10:59 PM
Carson Kit's Avatar
Carson Kit
Garth-
I just put the alternator back in and have the large power cable connencted at the 6 o'clock position.
I can't figure out the position of the ring connector cable - the only free posts are at 10 and 2 o'clock on my alternator.
Any suggestions?
Carson
Old Jul 9, 2004 | 01:29 PM
Carson Kit's Avatar
Carson Kit
Back to the top.
Can anyone tell me where the little wire to the alternator connects and possibly post a pic?
Regards,
Carson
Old Jul 9, 2004 | 08:41 PM
Garth S's Avatar
Garth S
This is a shot of the connections from an '80.
The power lead goes to the 13mm nut/post @ 6 o'clock. The second wire connects to the voltage regulator post (at 4 o'clock in the pic) with the 8mm nut - red connector. [ that is an aftermarket regulator, if things look differently].
Hope that helps.
File Type: jpg
Old Jul 11, 2004 | 05:38 PM
Carson Kit's Avatar
Carson Kit
Garth-
Many thanks - works great!
Another 928 is back on the road!!!
Best Regards,
Carson
