Window tint glue
I have a ton of the stuff on the windshield. Apparently there was tint on the windshield that I took off but I still have a lot of glue on there. What is the best stuff to use to get that crap off. Apparently alcohol does not do much at all.
HTH = Hope That Helps
Be VERY careful if your windshield has that plastic coating on the inside. "Sekuriflex"..Harsh things like acetone might damage it severely!
Mark, I do not have to be careful because I scraped that stuff out. I just have some residual glue left I need to clean up. With that plastic stuff in there you couldn't see 50 ft in front of the car. I am still amazed Styln drove here from Flai like that.
Originally posted by jserio
Thanks Jay. Where do you get it? Is that the name of the stuff or the chemical?
Also, What does HTH mean? My bro is wondering.
hth- (okay..Hope This Helps...)
I did most of the windshield with one. It was the filmy stuff that was a royal PITA.
Acetone =![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
The crap came right off. No arguement of discussion about it. You guys get another solute
Acetone =
Don't use a razor blade
you will stratch the glass! My window remover guy did this to me. Paint thinner for acycrilic paints is the best thing. Don't get it on other plastic parts though. Paint thinner is just the best at many things, if you have a stain on your carpets, paint thinner. If you need to clean your wife's suade shoes paint thinner. The list just goes on.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
