Steering Shaft Bearing
I think the bearing on my steering shaft is failing. There is a lot lateral play and the base of the steering wheel is starting to contact the dash.
On PET I see a bearing and a sleeve. Do they both need replacement or just the bearing. Any comments would be appreciated.
usually just the bearing . The thin race is very brittle and the bearing just disintigates !! I have the bearing the spacer and just about everything else !!
It is worth noting that this rubbing of the wheel will often wear out or break the L shaped horn contact which is part of the combination switch and NOT available seperately ........$$$
