928 Forum 1978-1995
Sponsored by: 928 Specialists
Electrical Gremlins Help!
Old Jun 29, 2004 | 06:37 PM
pasa's Avatar
pasa
Default Electrical Gremlins Help!
Help
while driving yesterday I felt my car jerk slightly for about a second and all my dummy lights on my dash would come on just for a moment and go then go off again. What could be causing this ? I suspect a corroded ground or is it possible that the brain is on its way out.
Any advise would be greatly appreciated
Dan
89 928 GT
Old Jun 29, 2004 | 07:02 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
I'd look carefully at the ignition switch and the "X" relay, in that order. Symptoms say that you lost power (not ground...) through the 15 bus or the X bus. 15 is on when the key is on, X is triggered off the 15. This is from memory so somebody jump in if I picked the wrong bus number for ignition-on.
Old Jun 29, 2004 | 11:16 PM
pasa's Avatar
pasa
Dr Bob
thanks for the info , how would you check the relay and or the ignition switch to figure out which one is the problem?
Dan
89 928 GT
