Update on 89 GT in "limp home" mode
Chronic Tool Dropper
I think there's a tech note someplace that talks about checking both EGT thermocouples. Kind of like the tail ligt warning system, the EGT system compares the two sensors, and shuts down a bank of injectors based on difference between the two. I'd start out reading millivolts from the two sensors at the controller/relay end and comparing, and even then I'd only replace the TC's in pairs.
Just a thought!
Just a thought!
pics of relay bypass
Here are some pics sent to me by David Schmidt ..showing how to bypass the temp sensor relay.... (when mine was acting up)...
Good luck...
Later,
Tom
Good luck...
Later,
Tom
Originally posted by Jim R.
John,
How would I bypass the relay? Is it possible The ezk relay or the computers (lh or ezk) could be causing this? I also replaced the eprom in the ezk with factory chip-took out an autothority set. Any thoughts are greatly appreciated.
Thanks,
Jim R.
John,
Thanks,
Jim R.
I am going to swap the old drivers side egt sensor with the pass side and see if there is any change. I will give you guys an update after the swap tomorrow.
Jim R.
Jim R.
