Post a picture of the hatch receiver it could be the insert has begun to crumble and is jamming the pop up part
The insert is new. The Hatch release dit work after I fitted it. If I push down on the plunger it doesn't get stuck when I release it. I have removed the whole assembly and checked that everything works with the remote release mechanism. The catch on the Hatch bit of the lock is a bit worn (rounded) but not so bad that the Hatch rattle.
Did it stop popping up after you installed the new insert? The fit might be too tight, try a little grease on the rubber insert and see if that makes any difference.
Stopped popping up a few months after.
Opening it with the key it doesn't feel as if anything is catching. I just turn the key and lift.
Will grease it a bit and report back.
