blue 89 project
#91
The second number on the cap is stamped in between the 2-3 or 6-7 exhaust ports.
Funny story.. Years ago I ended up with two heads with the same number stamped between the exhaust ports. Luckily, I had kept the the caps with the heads after disassembly.
Mrmerlin (09-18-2024)
#92
Here is the other number that Kevin is referring to, rufrob.
Kevin, to your point, I have 2 '062' heads here right now.
The caps that correspond to this head will say 1-171, 2-171, 3-171, and so on.
#93
Sheesh.
#96
NOTE after installing the cams and caps and verifying there properly spaced at 113 mm on the cam points .
Make sure the crank keyway is at 3 O clock this is 45 BTDC,so the valves will not hit the pistons.
Then you can rotate the cam pulley to see if the cams are binding,
if things dont feel free.
Then it would be wise to to start loosening a few caps to see if it makes any difference,
Otherwise you could seize the cams to the head.
NOTE only loosen one cap on each cam to test,
then retighten,
and loosen the next cap in sequence.
then retighten,
#97
I did as you suggested and loosening the cap caps didn't change the resistance at all. What did was more engine oil on the cams and lifters.
Still not smooth like the right bank but better
I moved onto the right bank now so VC came off easy and so far only 1 cam cap bolt stripped. Then the rain came so I'll leave it till the weekend. Who bets I can finish it this weekend?
9two8 (09-19-2024)
#98
#102
I don't like the Allens either. In fact, my set of triple squares has backed out a many stripped Allens. Probably a higher use case for them than as-designed, in my use.
Pro tip: If you have a GOOD set of triple squares, they will bail you out for handling a stripped Allen. Just drive in the next size triple square & hit it with a cordless impact.
Cordless impacts "hit" with a different action than air, which prevents further issue.
Mrmerlin (09-23-2024)
#103
Not sure it's fair to blame the bolts. I think it's the person trying to back out the bolts. I've learned that the shorter the distance from the ratchet to the head of either the triple square or Allen bolt the less likely you are to damage it. In my youth I used a long extension with an Allen to remove the Allen bolts that secure the seats. The results were mixed. But, now I know to use a low profile 1/4-in ratchet with an Allen wrench to remove them. Same goes for the triple square.
And I avoid using electric tools for the bolts. I always crack them and then reach for my Milwaukee.
P.S., I also use the low profile wrench for removing cam cover bolts.
#104
Agreed.. But, by the time I arrive, the damage is done. In that case, triple squares/extension bar & hammer/cordless impact wrench for me.
I haven't stripped one out, personally, in quite a while.
Stripped or not, I cannot even remember the last time I drilled or ground one. THAT is how effective my technique for fetching a stripped one is.
#105
And don't get me started on the low profile starter bracket allens. Drill baby drill.
My mechanic taught me tap the allen wrench socket tip into the bolt and press down as I turned it counter-clockwise. Sage advice.
I add anti-seize to the surface facing side of allens.
