928 Forum 1978-1995
Sponsored by: 928 Specialists
86 a/c issue and wire identification
Old Jul 22, 2024 | 06:07 PM
chakka's Avatar
chakka
Out of curiosity, ran a test wire to the compressor off the pos terminal and sure enough a hard click. So, what should I investigate with this now known information?
Old Aug 15, 2024 | 08:08 PM
chakka's Avatar
chakka
Getting back on the lack of a/c. Did an evac & refill (860 grams r-134), to make sure that was correct. Started the car, jumped from point under the hood directly to engage compressor directly. It engaged, but no cold air. Going to check low/high side pressures over the weekend. Now wondering if it’s the compressor as well as the hvac relay?
Old Aug 16, 2024 | 02:48 PM
chakka's Avatar
chakka
Doing some reading in here, does it take up to 20 min for an evacuated/refilled system to allow the air to start getting cold the first time it's run after this is done? I only ran it for 3-4 min with warm air coming out.
Old Aug 16, 2024 | 03:50 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
run the system and while thats happening,
put your hand on the expansion valve,
if it s not cold then its probably plugged,
NEXT look at the glass window and see if their is movement of the refrigerant.
NEXT verify that the compressor clutch is engaged and turning.
Old Aug 17, 2024 | 04:28 PM
chakka's Avatar
chakka
-Clutch engaged
-Looked at glass window and there was movement of refridgerant
-Hand on expansion valve(car running/clutch engaged) and not cold(no noticeable change from temp prior to starting car)
Old Aug 17, 2024 | 09:28 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
OK it sounds like the expansion valve is plugged,
so you might be ready to do a proper overhaul of your refrigerant system ,
this should include a new compressor and both of the flex lines,
a full system flush with new green O rings being installed after the flush.
new drier and expansion valve.
If possible use R12 and mineral oil .
NOTE if the oil in your system is not clear or lite tan ,
but maybe a rusty color,
then it indicates its been mixed with some other incompatible oil
Old Aug 18, 2024 | 09:38 AM
mj1pate's Avatar
mj1pate
+1
for cars at 30+ years old, it’s time. It also provides relief that the AC work is finally over, working at its best.
Old Aug 18, 2024 | 11:36 AM
chakka's Avatar
chakka
Putting together order, thank you for the help!
Old Aug 18, 2024 | 12:49 PM
steveymars's Avatar
steveymars
Have you put a set of gauges on the AC system? You can't really tell what's going on without knowing what the pressures are. It gets a little spendy just throwing parts at these 928s.
Old Aug 19, 2024 | 08:56 AM
chakka's Avatar
chakka
Yes, evac, pressure tested, refilled (860grams) R-134. Low was 48 & High was 105.
Went ahead and removed HVAC controller and wired in (via Dwayne's write-up) a new relay and added an inline 3amp fuse by the anti-freeze switch. So, now the clutch engages, via the a/c button(which it wasn't before).
Next is on to the vacuum system, since several of the settings don't operate, while waiting for new parts to arrive.
Compressor, receiver drier & expansion valve, heater control valve to be ordered.
Old Aug 19, 2024 | 09:17 AM
76FJ55's Avatar
76FJ55
that high side pressure seems quite low for a R134a system. I don't know what your ambient temp is, but I'd guess you should really be in the 250-300 range. Most R134a systems have a low/high cutoff switch with low cutoff point below ~27 and high cutoff above ~380. Based on your pressure numbers I'd say you're significantly under filled.
What method are you using to weigh the mass of the charge you are putting in?
Old Aug 19, 2024 | 10:46 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
NOTE the compressor flex line are known leaking culprits, if yours are old then they should also be part of your refresh process,
NOTE Griffiths has them reasonably priced.
Old Aug 21, 2024 | 11:12 AM
chakka's Avatar
chakka
Evac/pressure tested/refilled by a local P-car mechanic at his shop. If the compressor isn't working well, I'd assume that would contribute to the issue of (low) high side pressure. The other issues are byproducts of that, so I'd ascertain that a new compressor would be a big step forward with this.
Old Aug 21, 2024 | 11:13 AM
chakka's Avatar
chakka
Noted, thank you sir!
Old Aug 21, 2024 | 11:59 AM
76FJ55's Avatar
76FJ55
The high side will actually be controlled by the vapor pressure based on the temperature of the high side and having enough refrigerant in the system saturate the condenser. at only 105 psi U highly suspect you do not have enough in the system to have any significant quantity of liquid formed with the condenser.
the 43psi that you state on the low side would indicate that your compressor is doing a significant job of drawing the refrigerant out of the evaporator and you should be getting vent temps under 50F. but as you state you do not seem to be getting any appreciable cooling at the vents with that low side temperature it would indicate that you do not have sufficient liquid in the system to evaporate and cool the entire evaporator,
If your high side were low AND the low side were high I would agree that the compressor is likely inefficient, but as the low side appears to be within the expected range it appears to me to be more of a quantity issue than a mechanical issue.
For reference I ended up charging my 86.5 with rear air to 37 oz (1050 g) of R134a. Of course if you don't have rear air that would account for a lower volume.
