928 Forum 1978-1995
Sponsored by: 928 Specialists
Nice Article in Retrospect
Old May 20, 2024 | 12:19 PM
linderpat's Avatar
linderpat
Default Nice Article in Retrospect
A nice article by angus McKenzie in MT online. A couple of small inaccuracies, but overall pretty good. Here's the link for all of the pictures too: 75 Years of Porsche: Why the Classic 928 Is the Most Underrated P-Car of All (msn.com).
Story by Angus MacKenzie,
As I slide behind the wheel, I reflect it's been almost exactly 36 years since I last drove a Porsche 928. That car was an early S4, the first of the last generation 928s, and I still vividly remember the four days I spent with it. Back in 1987, it had seemed an impossibly fast and effortlessly competent machine, a 165-mph continent-crusher that made almost every other grand turismo on the planet seem fussy and fragile.
Even then, ten years after the launch of the first-gen model, the 928, with its water-cooled V-8 mounted at the front of the car, provoked controversy.
Real Porsches had air-cooled flat six engines slung out behind the rear axle. Anything else was a phony, and if you didn't believe that you could hand in your car-guy credentials then and there and go drive a Toyota.
It's hard to imagine in an era when
front-engine, V-8-powered vehicles are acknowledged as having been Porsche's savior and 911 engines have long been water-cooled, but the 928 was heresy incarnate for the Porsche purists. Heresy be damned! I loved that 928 S4. And ever since I've nurtured the belief that the 928 is the most underrated Porsche of all time. Now, 36 years later, I was to test that belief.
My yardstick is a 1981 928 S, one of 140 limited edition models sold in Germany to celebrate the 50th anniversary of the founding of the company by Ferdinand Porsche, Adolf Rosenberger, and Anton Piëch. It's finished in Meteor metallic, a dark silver-grey, over wine red on the dash, the seats, the floors, the steering wheel, the center console, the rear load space—everywhere. Only wine red and white striped cloth on the seats and F Porsche signatures embroidered in white on the headrests interrupt the 80s-era Dyonisian blush of it all.
The S was launched into Europe in 1980, three years after the original 928 had shocked the world at the Geneva Show, though it would not appear in the U.S. until the summer of 1982. It looked the same as the original; the big change was under the hood, where the 240-hp, 4.5-liter V-8 had been taken out to 4.7 liters and tuned to produce 296 hp. According to contemporary road testers, the S would sprint from 0 to 60mph in 6.6 seconds (in an era when a Corvette took 7.6 seconds), breeze past 100 mph in 14.9 seconds, and hit a top speed of 150 mph.
First impressions? It's way smaller than I remember. Back in 1987, my story was peppered with descriptors like 'big' and 'heavy'; today the 928 S feels no bigger than a 911. And in truth it is no bigger than a 911—it's 3.3 inches shorter, almost an inch narrower and four-tenths of an inch lower than the
current 911 Carrera 4 GTS. The low cowl and thin pillars give the cabin an airiness you simply don't find in cars designed to meet modern roof crush tests.
What's more, it's better looking than I remember. The 928 S4, I opined all those years ago, was not a pretty car: "It has neither the purity of line of a 911 Carrera, nor the dash and flash of something from Maranello. It's too wide, too squat…" But while the 928 S is slightly over-bodied at the rear, a fault fixed with by the S4's bigger wheels and tires, Wolfgang Möbius' sheet metal, created under the direction of then Porsche design chief Anatole Lapine, now looks fresh and original.
It was groundbreaking, too: The 928 was the first production car with bumpers hidden under plastic fascias that were seamlessly integrated into the overall bodywork front and rear, a technique used by every automaker today.
The 928 S4 I tested had been a four-speed automatic, the internals in the transaxle supplied by Mercedes-Benz. The then head of Porsche Cars Australia, Alan Hamilton, whose father Norman had in 1951 secured the first Porsche import franchise anywhere outside Europe after his rented Oldsmobile had been ignominiously humbled on Austria's fabled Grossglockner Pass by a 356 in the hands of Porsche test driver Richard von Frankenberg, reckoned only a dope would buy a 928 with the clunky five speed manual. He was right. And wrong.
My S is a manual, and even after a handful of miles it's clear the shifter's throw is too long and too wide, and the notchy action is a constant reminder that you're moving gears at the back of the car rather than right under the stick. But the pedals are well placed, allowing easy heel-and-toe downshifts. And it's fun to play with that wonderful V-8 under the hood.
Though the S4 had a quad-cam, 24-valve version of the Porsche V-8 that pumped out 315 hp on 95 octane unleaded fuel, the 296 hp SOHC 12-valve engine in the S feels only marginally less intense. That's partly because this particular iteration of the 'big' and 'heavy' Porsche grand tourer weighed just 3,196 pounds, or about 160 pounds less than today's entry-level, 370 hp 911 Carerra. Prod the gas pedal and the 928 S gathers momentum with a smooth, solid surge, the engine pulling hard all the way to the 6,100 rpm red line.
That relatively light weight helps the brakes haul the 928 S down from triple-digit speeds quickly and calmly as you work the five speed transmission back through the gears. There might be an engine out ahead of you, but there's a lightness to the nose, a delicacy to the feedback through the steering wheel, that you'll never feel in a 4,600-pound Panamera. I recall the S4 as being a car whose authority and stability at speed felt absolute. The S feels—in the context of the time, of course—much the same, though its smaller tires and softer suspension overlay that with an air of playfulness.
Like all great Porsches the 928 S feels hewn from a solid billet of steel, with nary a creak or rattle from the bodywork. The instruments, mounted in a binnacle that moves with the height adjustable steering wheel and are clear and easy to read, and you don't have to hunt and peck around a swarm of buttons or through a maze of menus to control things like the lights and wipers and air conditioning and audio system.
It's been more than 40 years since this particular 928 S rolled off the assembly line, and while it has covered barely 30,000 miles and been expertly maintained by the mechanics who look after Porsche's mouthwatering heritage fleet, it still feels like a car in which you could happily jump in and drive 1,000 miles in a day, arriving at your destination relaxed and refreshed.
"You come, in a very short time," I wrote in my 1987 road test, "to appreciate the sheer usability of the Porsche 928. Yes, the S4 is a supercar. But it's not one to be cosseted or pampered—it's just as unfussed going to the corner shop for Sunday's paper and a pint of milk as it is pulling 6,000 rpm through the gears on the way to that awesome 165 mph top end." It was, I said, the 7-Eleven Supercar: fast and convenient, 24 hours a day, seven days a week. Almost four decades later, my opinion hasn't changed. The 928 is still the most underrated Porsche of them all.
Old May 20, 2024 | 12:40 PM
Carrera51's Avatar
Carrera51
Thank you for sharing. Sent to my father in law who has owned an 85 928S since the early 90s. Still drives it regularly in nice weather.
