HEATER BLOWER
HEATER BLOWER
1986 PORSCHE 928 S2
Heater blower not working.
Relay seems ok.
If i put a jumper wire between pin 30 to 87 the blower works on all speeds.
when put relay back doesn't work.
Anyone got any ideas please.
Relay seems ok.
Team Owner
Did you put a different relay in for the blower ?
Have you verified that all the other relays in your CE are the correct ones and in the correct positions?
Did you replace the X bus relay?
Scroll down for 1986: https://928srus.com/pages/charts
Looks like Relay 4 is your X Bus relay.
Cheers
Cheers
Team Owner
to be clear,
have you verified that the correct part number relays are in the correct positions on the CE panel ?
Team Owner
NOTE disconnect the battery first.
OK look along the bottom edge of the CE panel for loose connectors,
and or individual wires that have come free .
next drop the CE panel and look for wires that might have gotten hot,
NOTE the insulation will have a satin finish instead of Matte.
First, are you getting voltage from the HVAC to the relay with the blower on?
Next, test the ground at the relay.
Either of those should point you in the correct direction.
Kevin
Kevin
Electron Wrangler
With the Blower Relay (X) out you can see if pin 86 in its socket is at 12V with Ignition on and HVAC head not turned off (blower switch doesn't matter), you can also test that socket pin 85 has continuity to ground. These are the only things needed to turn the relay on. Likely you don't have 12V on 86. NB For this year the X-Relay (IV) is not a factor
Alan
