Camshafts for 4,7 eur S(k-jet)
Hello. Im planning on making some upgrades to my -83 eur S. Im going to put S2 heads and rise the compression a litte to ~10.5:1. Ive been offered some hotter cams and would like go get some thoughts on them.
What do you guys think? Are these to hot for a CIS eur S engine?
Darklands (03-11-2024)
Presumably the cams, with limited overlap, can be used for K-jetronic if you can tolerate a bit of jerky engine at low revs. What kind of valve springs do you intend to use? The factory springs cannot handle this type of valve lift.
Åke
Åke
Tack Åke! Ive asked for specs on open/closing of the valves. I was not aware i needed different springs. Do you have any suggestions?
So i got some more info.
Intake opens at 7° and closes at 61°
Exhaust opens at 53° and closes at 2°
this is at 1mm lift.
picture shows these cams(blue) and a standard euro S cam(red).
