Chase bays dual piston brake booster delete system
This looks like a nice option for someone that just lost their booster and needs a new MC in their 928 .
You could probably delete the early car bias valves too. that will make bleeding much easier.
What fluid do they suggest?
Can ATE be used so it conforms to the rest of the original brake system?
Please post your thoughts after you have one installed, Thanks.
I messaged them Friday evening, but it was just minutes before closing, so I haven't gotten a response yet.. My "best guess visual eye" tells me that moving the master cylinder straight up will put the billet cap almost up against the bottom of the body/fender.. Stock master cylinders have the offset neck on the reservoir. I'm hoping this can be remedied in a couple of different ways. Ken
Do you guys think I should run a tee fitting from just below the master using the existing rear lines. Or just use one line and tee it near the rear of the car? Either way I think it should work, but much easier to just bend existing lines up front and tee it to an an3 adapter and run a short an3 braided line to the rear brake outlet on the master. Then run 2 10mm to 3an adapters and run 2 more short an3 braided lines to the L-banjo for the front circuit? Another user recommended I don’t ditch the diagonal braking system but I don’t see how I can keep it going this route. Thoughts?
i recently changed the oem MC in my C2 with a Wilwood because of poor brakes due 1" bore......the 7/8" Wilwood is already much better , i couldn't find a smaller one that fits the mounting flange....3/4" would be perfect.
I used braided soft lines to connect ... they use them a lot in rally cars .
That's why i wrote that 1" bore is big .....sure without booster.
I would love to have that setup for my datsun roadster. The brake pedal feel in those cars is hampered by a 4:1 ish ratio. Even the best mods (wedge behind the master, new clevis hole in the pedal) doesn't get close enough to 6:1 to make it work well. An adjustable linkage setup and keeping the brake pedal seems like a perfect solution.
In talking with a local big time Porsche racer, and SUPER NICE GUY, Quirt of Quirt Racing suggested just removing the supplied reservoir, and replacing it with nipples to remote mount the reservoirs... This will be easier on my race car, but should be doable on a street car also. Ken
The following 5 users liked this post by Iamwilliam:
davek9 (08-10-2024),
Michael Benno (04-05-2024),
Mrmerlin (04-07-2024),
PorKen (04-05-2024),
Zirconocene (04-05-2024)
