Euro bulb comparator
Just so I don’t chase my tail on this one, I’ve got the tail light warning indication when turning lights on. Now this happened in my 83 US car and I found different brand bulbs in the rear marker lights and it fixed it. The 84 Euro has been federalized so I’m wondering since marker lights have been spliced in the bulb warning will stay on?
The warning computer only looks for a variance in current pull between the two circuits ie marker lights, brake lights, etc. It doesn't care so long as they are the same. Even different brand lights can set it off.
You can delete the marker lights if you want with no ill affects.
Team Owner
make sure the side marker 2 pin connectors are clean use D100 on everything
