Question about 928 classics initial air/fuel set up setting?
1978 US Auto. 928 classics PDF says to turn screw all the way counterclockwise and then go clockwise until you hear injectors engage and then go back 1/8 turn counterclockwise. My question is what constitutes the point where I stop and go counterclockwise 1/8? I hear two sounds - a quiet hiss and then the full Scream/squeal sound. There is a point where the injectors start to scream, but further counterclockwise for at least a whole turn, I still hear a soft hiss. Is the correct setting 1/8 turn back from full (loud) injector spraying or is it 1/8 from when I can no longer hear anything?
Those directions were a bit too subjective for me as well. If I can find my setup instructions from Flowtech, I’ll shoot you a message. Gauges, as I’m sure will be recommended, are good to have.
